Evo LSD Finally done...
#31
How does it affect the ABS? Do any of the parts manufacturers do anything but drag race their cars? Take that thing to an auto-x or road course and let us know how it does. Kudos to TT for getting their product out there first, but there's a lot of us who rarely (if ever) see a dragstrip.
#33
Originally Posted by 94AWDcoupe
A few years ago when those things hit the market a couple of locals had them installed in their gst cars. Both cars broke the front diff within two months. There has been good results seen in awd cars using them. Drops 60ft about a tenth and makes launching more consistant. I haven't seen an awd car break a diff with it. But there is less stress on the front diff in an awd car. I had one in my yellow car. After seeing the wear pattern on the gears after just 2000 miles I took it out in favor a factory torsen diff. The torsen diff did wonders compared to the phantom. I will stick with honest reviews of parts. And I will stick with my opinion that the phantom should be chosen with great caution. the front diff cannot be bought sepataely as of yet for the EVO8. An new one costs 2000.
Keith
Turbotrix Racing
#34
Props to TurboTrix
This post is meant to let the people be aware of an option. Just let it be known this is an INSERT (BMTranny or Phantom Type), not a true LSD.
The insert is an alternative to lower your 60' by around .10 of a sec.
#35
I am going to jump in here and back up TT a little bit. Assuming that their design is similiar to the phantom grip lsd insert, it does make a difference for AWD. I've got a phantom grip in my GSX and it's been in there for something like 4 years or so, maybe 3.5. It obviously does not work as well as a true lsd, but it is definitly better than a open front diff, especially in straight line runs. A true lsd helps out alot more in turns as it locks the outside tire to provide power instead of spinning the inside wheel. Phantom grips dont really do jack for autoX. If you do autoX, wait for a real lsd. If you like drag racing, then I see no reason not to splurge on the 300 dollar TT phantom diff. Also, the phantom diff's were over 300 when they came out for the 2G's. As more are sold, I am sure the price will come down.
#36
For those that autoX, be very careful mixing the ABS braking with a front, center and rear limited slip. (Evo's have center and rear already of course). You have a very good chance of breaking something if you get into ABS pulsation while AutoXing with a real front lsd. This is the reason why its not availble on a evo with ABS, yet, the STi has a front lsd. STi's computer controlled diffs can work with ABS, Evo mechanical diffs cannot.
#38
Long Island, NY here.. I was planning on coming out to TT to check out their shop at some point in the next few weeks. I can see the merit of the argument about this "LSD".. but we don't have much of an alternative at the moment. My right front wheel spins pretty often.. so on a good launch (or even a third gear "Data log pull") my left front hooks and I just go to the right..
It is what it is.. but it IS affordable and IS a good option if you dont need to spend a fortune on a torsen diff..
#40
Why not try and get hold of an Evo 8 RS front diff? Don’t know if Mitsubishi would want to supply them but there must be a way for you get them! This is what a lot of people over here in the UK do if they have a GSR but are scared of wrecking the rear diff, but as Mitsubishi won’t supply the diffs (be it front or rear) on their own so we have to fork out something like £5k for the whole lot!!!!!
Do you guys have any problems with the rear diffs (GSR model)? In the UK (on the earlier cars) this is where the weak point in the transmission seams to be.
Thanks Chris.
Thanks Chris.
#43
d3wu, from what I have heard from the UK guys the AYC diffs (the rear one on the GSR) are inherently weak. The casing is much thinner than the RS casing (I think it is down to 2mm in one stressed location). I admit that most of the problems in the UK have been on cars up to the 7 (I think they sorted the lash angles out then) but it still may be a problem on high powered cars or anyone that is doing standing starts. As for the active centre diff, you may be able to get one from the UK or Japan. I not sure what the fit would be like (LHD compared to RHD)! I don’t know why you guys didn’t get the active centre diff anyway, so there may be a reason! I don’t think there ever was an active front diff (RS has a viscous LSD) and if it was a custom job then you are looking at BIIIIIIIIIIIIIIIG money. If I where you I would leave that to the WRC teams and get a RS setup, IMO of course.
Hope this helps.
Thanks Chris!
Hope this helps.
Thanks Chris!
#44
2GDSM You are just plain full of ****. I ran my car at Pocono last week and embarrased a few Porsche and Corvette guys. The front LSD works perfectly in conjunction with ABS. The rumor that a front LSD dosen't work with ABS got started with one of the Car mags after Kevin Buckler made a comment. He's a Porsche guy forever! A Torsen front diff is a great mod for this car, period.
Cheers,
Cheers,
