Is Speed-Source reputable?
ordered about 100$ worth of items from them early in the month. took about 4-5 days to recieve any confirmation from them & i now have some unresponded e-mail messages & im getting a bit concerned...... anybody here have any experience with this company?
I have dealt with Speed-Source on multiple occasions. I have had nothing but positive experiences with them. Carl might be a little busy, so I'd try him again: cacrawfo@speed-source.net
Im guessing they're just alittle backed up as well. I ordered up the usual combo from them (bushings and clutch line) after reading the good reviews on here. I dont think I could have asked for better service, and Carl even accomodated my request for a "non-rice" colored sheathing on my clutch line.
there's two different kits that they sell.one for the shifter cable which consists of two metal bushings.then the base shifter bushing which has 8pcs of metal bushings.both of them are made for the evo probly cyanide got a mix up on his order so they sent him a different kit.
How easy it to install the bushings? It says thirty minutes, but me being a little slow it'll probably take about three hours to install them. Also, how long does it take to install the clutch line?
the cable bushings not too bad to install it took me about 45 mins.as for the clutch line it should be pretty straight forward as long as all the tools youre gonna need is ready.also an extra pair of hands would also be good so get one of your buddies to help even if its just to hand you tools or what not.
Originally Posted by johny719
if theres 2 available kits for the mitsubishi evo 8... then which one is the correct one?
Install took me 15 minutes, but I didn't remove the battery or anything. Work space is tight, but manageable. If you're doing the clutch line at the same time, you'll have to take out the battery, etc... and will have a lot more room to work with.
