What's Our evo's actual weight??? G-tech owners help!
Just got the G-tech pro comp and wondering what's our evo's actual weight to be put in into the gtech..
and i have a problem with the rpms...
i have calibrated the rpms and when i go to the drag mode and the tachometer is wrong! it even jumped to 6k out of a sudden and stayed there...
have anyone experienced this?? what should I do??
please help.. thankss
The RPM callibration thing has been covered before. I usually turn on the headlights and then callibrate; if that doesn't work try adding the blower fan. I set the high RPMs to 6500 and the low RPMs to 1500. I also have a friend calibrate the G-Tech so I can focus on the road and tach.
For weight I have been using 3500 lbs. I have an Evo with a sunroof, generally 3/4 tank of gas and me.
