Guaging interest: RS Rear Cross Bar...
Originally Posted by speedomodel
I'd like to know if we have to cut the plastic trunk trim in our normal EVOs to get it to fit. If mods are minor, I'm in.
I'm interested. Let me know. As for cutting the plastic (if needed), you should pull out the piece of plastic and measure where the bar sits and figure out what needs to be cut to make it fit and then draw nice lines and cut it with an airsaw or a cut off wheel. Doesn't sound too difficult.
i've examined the trunk and i think i see where this bar mounts (you have to take the two black circles off the floor to see the holes). if it is the right spot, then depending on how tall the bar is, you will probably only have to cut off the plastic that is below the carpet level (the part of the plastic that bends toward the back of the car) to make it fit. thats not a big deal and you'll never see it.
Got the first 3 in today. I will install it in the next day or so and take some pics to make sure everything fits good.
The remaining ones are on backorder... but we should be able to get them soon.
