What does "under $30K" mean?
Would you prefer I compare to a Mustang?
Acceleration is only one aspect of performance, and some of the riceboys floating around here seem to think that's the only aspect. I don't believe that SirLancerLot was trying to say that braking was not important, but there are a lot of people who seem to think so.
Regardless of what SCC writes, the true measure of a high performance braking system is not measured in a single 60-0 stop (which should be stricken from all magazine reviews, IMO). Rather, it is measured in its ability to stop/slow the car from high speeds repeatedly. For example, 95-40, 60-40, 85-45, 90-50, 85-50, 75-40, 105-40... repeat... (that's what my S2000 goes through every lap at the track). Bigger brakes *will* help (bigger -> more heat absorption to the rotor -> lower brake fluid temps -> more consistent stopping power). Smaller rotorss can equal "big brake kits" in the 60-0 category, but in repeated stops they will eventually lose, all else being equal.
You brought up the tuning/upgrade factor, but that is completely irrelevant to this discussion - because *most* people won't replace the stock brakes or wheels. Thus, the Track package is still the most desirable of the new Zs.
SirLancerLot - if you ever read Evo, you'll notice that they do much more extensive acceleration/deceleration testing. I believe they use a GPS logger and accelerate from a stop to top speed, then get on the brakes and go back to 0, and report all braking intervals. Gives you a good idea of what the brakes are really capable of.
Guack - I think that was mentioned in the SCC article. Regardless, it's a very good point with upgrading brakes, but should be a non-issue with OEMs.
blackevoVII
Feb 13, 2002 09:13 PM
