Nokon Cable Housing for Sensor Wiring
Just experimenting last weekend with the best way to cover the exposed copper wire running from the pyrometer sensors on my exhaust manifold back to the firewall. I ended up trying Nokon bicycle cable housing. I use it on all my bikes -- not exactly cheap but well worth the expense.
The Nokon housing uses a slip-on Teflon liner and small ball-joint aluminum links. I left the original wire loom and continued with the links from there. I was a little worried about how it would handle heat, especially the liner. So far it's working fine. Eventually, I'd like to find a better collector / routing method than zip-ties. What do you guys think?
speedomodel
16
Apr 16, 2007 12:55 PM
speedomodel
13
Sep 3, 2005 02:14 PM
speedomodel
Dec 30, 2004 01:57 PM
speedomodel
Nov 16, 2004 01:32 PM
