Starting point for Defi Gauges?
I just bought 3 Defi D-gauges, the ones that don't require the link. The boost gauge reads zero in the box. But the EGT reads about 600 degrees and the oil pressure reads 20 psi. Is this okay? Is it because the oil pressure and EGT are electronic and they will zero out when they are hooked up and the car is turned on? I know the boost gauge would have to read zero considering it is mechanical.
the guages are indeed electronic so they should go to 0 when you give them power. try hooking them up to power and see if they go back, mine did. if that doesn't work, than you should contact defi
good luck
good luck
