What will run... (searched)
if i have a full turbo back, boost controller set to 20-21 psi all the way to red line, k&n flat drop-in, and turbotrix dyno flash... do u think ill be able to hit 12's w/ a new clutch???
im basicly stock runnin 13.7@99mph on the stock clutch....
1 Post
you should easily run 12's... My guess is you'll be making around 350-375 hp... so hitting 12's will depent on the drivers skills and ability to launch an AWD car. What elevation are you at?
1 Post
well at about 100ft elevation i ran 13.5's consistant with shipping blocks still in the springs (I was unaware of them until i serviced the oil and saw them...) the mechanic hella inspected the car before they sold it, my @$$ he did...
with those blocks the car had nasty wheel hop and would bounce off the line, yielding only 1.8's so i'm guessing the car itself is capable of atleast 13.4's if not slightly faster...
You should be able to run in the mid 12's at least, I would guess low 12's but don't hold me to that
