Need a little help with transmission fluid
Old Aug 11, 2004, 04:51 PM
2004BlkEvo8's Avatar
Ok, I just put 1,200 miles on my Evo and I wanted to change out the transmission fluid, transfer case and rear differential fluids. I've never done this before, so I didn't know which fluids, they looked it up in the computer, and this is what they gave me! They seemed confused so I just wanted to check and see if this is the right shizzle before I F my transmission or anything up. They gave me this huge F'in jug of SAE 90 for just the rear diff, and 5 of those BG 75W-140 for the tranny and transfer case.
Is the part number for the oil filter right? I think they just hosed me for 10x more rear diff fluid than I need, but I guess it will keep till I do it again. At first they gave me tranny fluid for a regular '04 Lancer, and I called them on it, then they brought out this stuff 30 min later.
The part number for the rear diff, the huge f'in jug was: 3775610
752 for the other 5 bottles.
I'm planning on changing the fluids tomorrow, any insight would be great, I dont want to put the wrong shizzle in.
Thanks
-Dave
Attached Thumbnails Need a little help with transmission fluid-tranny-fluid.jpg
Old Aug 11, 2004, 06:13 PM
JustDSM's Avatar
The DiaQueen oil is for the rear diff and transfer. I strongly suggest you do not use the BG fluids in the transfer.
Old Aug 11, 2004, 06:14 PM
Bump... anybody?
Old Aug 11, 2004, 06:16 PM
Thanks for the reply!
Really? They said just use the Diaqueen for the rear diff and use the BG for the transfer case and tranny.
Old Aug 11, 2004, 06:39 PM
EVOTEXAS's Avatar
BG only goes in the transmission. The rear diff and transfer case get the SAE90.
Old Aug 11, 2004, 06:41 PM
Okay thanks for the replies... I'll be putting the SAE90 in the transfer case and rear diff and the BG in the manual transaxle
Old Aug 11, 2004, 07:00 PM
g6civcx's Avatar
I recommend that you return the Mitsubishi oil filter, and instead, go buy a K&N HP-1008 Performance Gold oil filter. It will cost about the same as the Mitsubishi.
I like the K&N because it has a nut on top. You can put a 1" socket over it and turn it to loosen the filter.
Old Aug 12, 2004, 12:12 PM
maybe next time, I already have the mitsu filter and the dealership is an hour away...
Old Aug 12, 2004, 12:18 PM
lil'evil_evo's Avatar
How much did they charge you for the SAE 90 jug?
Old Aug 12, 2004, 12:19 PM
marksae's Avatar
Read this thread:
https://www.evolutionm.net/forums/sh...41#post1134841
Here's the fluid specs from the shop manual.
Old Aug 12, 2004, 12:23 PM
Too much... like 60 bucks
Old Aug 12, 2004, 12:25 PM
Holy $hit I have alreay spent too much on fluids would you like to send me your jug after your done
Old Aug 12, 2004, 12:28 PM
93civEJ1's Avatar
yeah, i think the jug they gave you is for both the diffs, but id skip the BG. So i can go to the dealership and get a big jug of this??
Old Aug 12, 2004, 12:31 PM
I just seem to be reading a lot of different things. I decided to go OEM just to be careful. As far as reading the manual, it is safe to use the DiaQueen SAE 90 in the rear differential and transfer case. How do I know if its GL-5? It doesn't say on the jug.
The BG fluid for the manual transaxle... well it says 75w-85 or 75w-90... and the bg fluid the dealer gave me is 75W-140
Is this safe to use?
I want a bunch of opinions, just so I dont ruin anything. The car only has 1,200 miles on it, I'm not yet ready for anything to break!
Old Aug 12, 2004, 12:36 PM
They sold it to me, I dont see why they wouldn't sell it to you. If you dont mind having A LOT extra. I figured it wouldn't hurt since there will be more tranny fluid changes in the future.
Quick Reply: Need a little help with transmission fluid
