IC spray runoff?????
Old Aug 19, 2004, 02:32 PM
evilution8's Avatar
hey i noticed the last few times of putting some distilled water in the IC spray reservoir that is spills out onto the driveway from underneath the car. is this just a runoff that means its full??? Or did i i crack a line over winter and its leaking?? ive heard a few people say it actually has a runoff spot where you cant fill it anymore then it leaks out the side.
Old Aug 19, 2004, 02:33 PM
alex_alex's Avatar
hope. perfectly normal.
Old Aug 19, 2004, 02:34 PM
EVOL 8's Avatar
I've heard the same...maybe just overfilling it.
Old Aug 19, 2004, 02:42 PM
Ty-Evo8's Avatar
I had the same thing happen to me when I filled it for the first time. I hear that it’s normal… even though I don’t understand why Mitsu felt the need to do this.
Old Aug 19, 2004, 02:45 PM
BRKENG's Avatar
yup...normal... I took apart my whole front clip practically to root cause the leak and discovered, hmmmmm over fill hose vents to atmosphere wtf. But really , where else is it going to go?
Old Aug 19, 2004, 02:48 PM
machron1's Avatar
It's not the fact that it has an overflow hose that is odd, it's that it is located at the base of the filler neck, not at the top where I would consider it "overfilled". There is a lot of empty filler neck space even when it's "full".
Old Aug 19, 2004, 03:02 PM
BRKENG's Avatar
Agreed, when you look down the spout it seems there is a ton of room for volume, perhaps there is a heat distribution there that can melt the hose if its up higher?
Old Aug 19, 2004, 03:17 PM
mifesto's Avatar
by the way u shouldnt run distilled water for it, you will rust the intercooler.... mitsubishi recommends only windshield wiper spray
Old Aug 19, 2004, 03:19 PM
BRKENG's Avatar
Isn't the intercooler Aluminum? The oxidation rate of aluminum is quite low by comparison to ferus metals.
Old Aug 19, 2004, 03:21 PM
justchil's Avatar
Just fill it up to the drain tube located on the passenger side of the tank
Old Aug 19, 2004, 03:25 PM
dpardo's Avatar
Maybe filling the tank beyond that hose would incur a weight penalty that would offset any gains from the spray system?
Old Aug 19, 2004, 04:46 PM
machron1's Avatar
You think that 2" in height is gonna make a difference heatwise? Maybe but I doubt it.
Technically aluminum doesn't rust, but it does oxidize. However, I seriously doubt windshield washer fluid will protect it from oxidation considering all the crap from the road and rain gets all over it, not to mention when you wash it. I know recommends windshield washer fluid, but do you really want your intercooler to be blue all the time?
Hmmmm...I knew my lap times would have been better if I hadn't had that tall drink of water before I got in the car
Old Aug 20, 2004, 06:54 AM
BRKENG's Avatar
you never know, we have had heat distributions and anomolies in test vehicles in death valley several times. I doubt it. It was more in jest though hehe.
Old Aug 20, 2004, 06:58 PM
g6civcx's Avatar
Distilled water will rust the intercooler?
What about rain water?
Old Aug 20, 2004, 10:07 PM
alex_alex's Avatar
actually, water is fine. the only reason mitsu suggests using wiper fluid is so it wont freeze in cold areas. Luckily, we don't have to worry about that in Cali.
