LanEvo VII ECU diagram
Hi there...
was wondering if anyone of you have the diagram for the VII's ECU... as in which plug and wires are for what and so forth.... need to do some installations of my own...
thanks...
thanks...
I found this on the MLR forums, don't know exactly what version of the 7 it is and how correct it is:
PINOUT LANCER EVO 7
Connector layour
|A01|~|A13| |B01|~|B08| |C01|~|C06| |D01|~|D11|
|A14|~|A26| |B09|~|B16| |C07|~|C12| |D12|~|D22|
A01 INJ #1 CYL
A02 INJ #3 CYL
A03 F/PRESS SOL
A04 STEPPING MOTOR (A)
A05 STEPPING MOTOR (C)
A06 2ND AIR SOL EGR SOL
A07 (N . A)
A08 F/PUMP PELAY
A09 PURGE SOL
A10 IGN COIL1 #1/#4
A11 W/G SOL
A12 BATT.
A13 PWR GROUND
A14 INJ #2 CYL
A15 INJ #4 CYL
A16 (N . A)
A17 STEPPING MOTOR (B)
A18 STEPPING MOTOR (C)
A19 AFS ACTIVE FILTER RESET
A20 FAN RELAY (HI TEMP)NA
A21 FAN RELAY (LO TEMP)4KHz
A22 A/C RELAY
A23 IGN COIL2 #2/#3
A24 (N . A) A/C 2 SW (H/L)
A25 BATT.
A26 PWR GROUND
B01 (NA)ALT/LAUNCH SWITCH
B02 (NA) RAD FAN SLW
B03 ALT-G NOT USED
B04 (NA) FAN
B05 I/C SPRAY LAMP = ICLED
B06 ENG CHECK LAMP
B07 P/S SW
B08 CONT RELAY (W/ DIODE)
B09 F/PUMP PELAY (H/L)
B10 (NA) NOT USED
B11 ALT-FR NOT USED
B12 (NA) NOT USED
B13 (NA) ACD HI SIDE
B14 (NA) I/C SPRAY SW (AUTO)
B15 A/C SW A/C 1 SW
B16 (NA) NOT USED
C01 (NA)
C02 (NA)
C03 (NA) 2ND AIR SOL
C04 (NA) OX HEATER GND
C05 (NA) I/C SPRAY RELAY
C06 DIAGNOSIS CONT SIG
C07 (NA)
C08 TACHOMETER
C09 (NA)
C10 O2 HEATER CONT (6W)
C11 (NA) COMMS GND
C12 DIAGNOSIS K
D01 ST . SIG
D02 AIR TEMP SENSOR
D03 (NA) MDP SENSOR
D04 (NA)
D05 (NA)
D06 O2 SENSOR
D07 (NA)
D08 KNOCK SENSOR
D09 FLASH EP-ROM BATT
D10 BATT . (BACKUP SOURCE)
D11 SENSOR SOURCE (5V)
D12 IGN SW
D13 WATER TEMP SENSOR
D14 TPS
D15 BARO . PRESS SENSOR
D16 VEHICLE SPEED
D17 ID . SW (TPS W/)
D18 #1 CYL DETECT SIG (SGC)
D19 CRANK ANGLE SENSOR (SGT)
D20 AFS
D21 NEUT SW I/C SPRAY SW (MANUAL)
D22 SENSOR EARTH
PINOUT LANCER EVO 7
Connector layour
A01 INJ #1 CYL
A02 INJ #3 CYL
A03 F/PRESS SOL
A07 (N . A)
A08 F/PUMP PELAY
A09 PURGE SOL
A10 IGN COIL1 #1/#4
A11 W/G SOL
A12 BATT.
A13 PWR GROUND
A14 INJ #2 CYL
A15 INJ #4 CYL
A16 (N . A)
A22 A/C RELAY
A23 IGN COIL2 #2/#3
A25 BATT.
A26 PWR GROUND
B03 ALT-G NOT USED
B04 (NA) FAN
B06 ENG CHECK LAMP
B07 P/S SW
B10 (NA) NOT USED
B11 ALT-FR NOT USED
B12 (NA) NOT USED
B15 A/C SW A/C 1 SW
B16 (NA) NOT USED
C01 (NA)
C02 (NA)
C07 (NA)
C08 TACHOMETER
C09 (NA)
C11 (NA) COMMS GND
C12 DIAGNOSIS K
D01 ST . SIG
D02 AIR TEMP SENSOR
D03 (NA) MDP SENSOR
D04 (NA)
D05 (NA)
D06 O2 SENSOR
D07 (NA)
D08 KNOCK SENSOR
D12 IGN SW
D14 TPS
D16 VEHICLE SPEED
D20 AFS
D22 SENSOR EARTH
