DEFI Boost Gauge does not work after Dealer warranty service
Ok, first let me qualify this by saying this is not an evil dealer rant. I like the dealer I use very much and I am not angry or p*ssed at them or whatever because they do great work.
I was having a problem where the HVAC knobs were binding and it was very difficult to turn them. I left the car at the dealership on Monday the 30th to fix this, under warranty and they finished it up on Thursday. The reason it took 3 days is because they had to take apart the dash board in order to replace the heating unit.
Now when I go to pick up the car, the service manager pulls me aside and explains that my boost gauge is not functioning. She said the mechanics looked at it for a while, but couldn't figure out what was wrong, mainly because they have never worked with this model of boost gauge (DEFI). She then said that they feel bad about it and will pay any costs associated with fixing it.
So I looked at it this morning and the control unit is functioning fine. Whenever I boost, the control unit starts beeping because I went over the 1 bar default warning. The control unit's lights also work well. My Greddy Profec II and turbo timer also function fine.
The boost gauge- DEFI black face, has its needle stuck on 1 bar. The gauge does not light up or move at all. I checked the wire from the control unit and it was in tact, i.e. not cut or crimped. I have no other DEFI gauges so I don't know if the problem is isolated to the boost gauge or not. I am confused as to why the control unit would function, but the boost gauge would not. I mean, the boost gauge does not have seperate power connections.
Does anyone have any suggestions as to why the boost gauge would not be functioning? Anything else I should check? Or is the unit dead and I should order another one?
Thanks,
Brad
Thanks,
Brad
Did you check all your hose connections to the boost gauge and the fuel pressure solenoid? Wait a minute...what am I saying? There is only one hose, so the connection should be easy to check. If not, it's the boost gauge itself.
CO_VR4
10
Dec 31, 2016 06:23 PM
MONSTARR
12
Jul 26, 2007 09:32 AM
RavSpec
28
May 11, 2004 11:36 PM
