help
help
hey, today i blew a fuse and so i had to remove the front ECU to get to it. If i removed the ECU, will it effect anything? sorry if im in the wrong area, move it admins if it is.
Long as you put em back, nothing bad will happen. I disconnect my ECU all the time, because of this damn misfire and lack of CAT Engine lights. lol.
You blew a fuse and you had to remove the ECU? ECU is in your passenger side and your Inside fuse box is in your driver side... Am I wrong?
