Defi guages
Originally Posted by boostfed
I'll post some pics of mine when I install then this week. should be here anyday. I order the Defi D-series black face boost gauge. I'm not sure, but isn't the D-series the only one that reads boost in psi instead of bar.
-Chad-
-Chad-
i've got d-series gauges and i love them. take a look here.
www.cardomain.com/id/scorpiotypes
Originally Posted by Outlaw
How do you like the Defi Link VSD? Does it make it easier to see your speeds/rpm's and stuff? Was thinking about getting one but not sure if it will serve a good enough purpose.
With my height, and the placement of the speedo dials in the dash, I can never really tell the speed I am at until it hits about 140km/h which is WAAAaaay above the speed limits here
The VSD Concept helps in that respect. Visibility is a bit obscured sometimes in the day and when there is a lot of reflection on the windscreen. There is a small piece of polaroid type film that you can stick on the windscreen to improve that, but I didn't bother with it.
I still use the BF gauges for boost, oil temp and exhaust temp. The VSD is also used to warn if my water temp exceeds the threshold.
