Question for the experts.
My car is currently bone stock, that's all about to change in the near future.
I plan on installing an MBC (just to eliminate the possibility of the stock BOV leaking and to hold boost to red line), HKS Racing Suction Intake System, and an EVO MR Blow Off Valve. I have a turbo timer and a Boost Gauge also, but I know these don't matter one bit to my question.
Question:
With this modest setup, should I need to worry about having my car tuned to accommodate the increased air flow made by the HKS intake? Will the car run too lean? I hear from the factory they run pig rich .... so I'm looking for advice.
Also, once I have these mods done, what would you recommend be my next upgrade. I was thinking a Turbo Back exhaust...
All in all, I'm looking to get to the point of making about 350 WHP and call it a day, this is my dd and I am not looking to take it to the bleeding edge (maybe one day but not now).
Thanks for any input!
Question:
You'll be fine with those mods and no tuning, but if it were tuned in any way it would of course be better. As far as a tubo back being the next mod after your list I think you are right on track.
As fas as tunners go, I'm even afraid to ask for an opionion, that's when the trolls come out, but if your brave I would also appreciate your opionion.
Thanks again!
Look at AMS turboback, ive heard they are very quiet but with a great tone!
www.automotosports.com
Personally i think you will see the biggest gain with a downpipe and cat-back exhaust and depending on where you live a cat delete pipe. HKS, Greddy, or JIC make a very nice exhaust. I have the HKS Carbon Ti which is very very nicely built and it is not very loud at all. The MBC wont help with a leaking BOV but it will help with the holding boost till redline. The stock BOV should be able to handle the 21psi you will probably be pushing to redline but the MR would be nice since you are planning on that anyway. I would then get a HKS Intake IMO. They have showed major gains on the dyno upwards of 9whp-10whp. They due lean out your car but nothing to be worried about. I would say you are fine with the tune till you get injectors or you just want to raise the rev limiter or remove the speed limiter. Just my 0.02
Chris
Chris
Originally Posted by alex_alex
this is a pretty common misconception, but the boost taper you see is not b/c the BOV is leaking. the ECU is programmed to taper
This is a "my bad" I was trying to convey to many thoughts and did not type that up correctly. I understand that the boos taper is programmed into the ECU, what I ment to say was " I'm upgrading the BOV to elimnate the posibility of leak i nthe future not to elimnate the taper".
Now my qustion is , Why does the stock ECU settings taper boost?
Chris
Chris
I was typing my thoughts out too fast, I do understand the the MBC wont help with a leaking BOV, I don't even know why my brain didn't catch that. All the mods I listed above I plan on installing at the same time, the exhaust is a later purchase.
Thanks for your input
Originally Posted by LancerOZ!=Evo
...Question:
l8r)
RalliArtEvoVIII
Mar 5, 2005 08:44 PM
Boost Solutions
May 12, 2004 11:33 AM
