Bolsen's Guage cluster light mod ROCKS!
Hey guys,
Ever since I bought the EVO, I sincerely HATED the dash lighting at night. I waited and waited for a solution, but nothing had satisfied me, until i saw a post from BOLSEN. After his ingeneous mod the cluster is 40-50% brighter than before! NO EXAGGERATION! Thank you Bolsen! You have saved my aging eyes from getting worse THIS IS THE ABSOLUTELY BEST Mod I have ever done!
Click link to see directions.
http://bolsen.homeip.net/index.html
Bobby
Bobby
am i the ONLY one with bad luck or what..
i did everything right until i pulled off the last blue cover and the light went with it.
now when i plug the light back in it wont stay.. so i decided to add some adhesive to hold until i can get a new one.. well... now the ENTIRE cluster doesnt have power except to tell you the door is open.
did i fry my cluster?
i checked twice. but will try again.. it smelled like the adhesive "burned" off then the whole cluster doesnt light up.. no power to it. i turn the car on and non of the gauges work the odo,tach,speedo all dont work.
damn, thats not a good sign, you may want to see if your fuse is blown. I am not sure which one it is, but there is a fuse box inside the cabin and inside the engine bay. See if any of those are burned out.
haha. thanks man. i was looking around for it.. and didnt refresh thread.. thanks again
btw.. it did improve the brightness ALOT.. now off to mitsu to buy new bulb.
thanks again
thanks again
no prob! but be prepared to get raped by the dealer. It costed me $4.80 for a little bulb:O I tried soursing it from autozone but they said it was a dealer only item. Did you notice that the ends of your bulbs were brown? all of mine were, which worry me, it seems like there are alot of guys with evos that have burned out dash lights, i dont want to open up and replace every bulb every year. this must be some design flaw, i think it may have to do with the dash guages being "on" during the day and night.
yea. there is a thread with a bunch of people having to replace their bulbs.. i wonder if it is covered under warrenty.. the 3yr/36k probably not.. "you mod your car, and now its has too much hp for the bulbs to work properly, at you rate your paint will start to peel right off" oh how i can see the techs saving that. but i have a pretty cool dealership(so far) so hopefully they can give me a good price on the bulb
What about using this EL foil to slid under custom make faces. Anybody try this ??
http://www.cooltronix.com/shop/index...t=EL_Wire.html
Look at the foil sheets.
