DIY Better adjustable stock BOV!! Free mod!
Old Oct 4, 2004, 01:16 PM
kuniboy's Avatar
Here's a mod to improve the stock bov pressure holding capability. This mod is similar to the 1G BOV crush mod. Unlike the 1G BOV , the Evo's BOV is plastic therefor we cannot use the crush method. Instead, we will SCREW it! Well, here's how.
(1) get 2 - 3 fine thread screw shown in pic.
(2) Drill one hole at a time on the top of the BOV. The holes must be drill on the outer top of the BOV. you want to drill starting from where the spring coil ends. You can locate the spring by simply puting a magnet on the top of the BOV.
(3) After you drill the hole, you will see the metal spring under the plastic that you've just drilled. 1 or 2 screw should be enough. If you failed to locate the spring on the first attempt, just simply close the hole with a screw. and then try again.
(4) The drill bit that you use should be slightly smaller than the screw you have. This way the screw will go in snug.
(5) After you have finished with the mod, replace the BOV and go for a test! Tightening the screw too tight will create the stalling problem associated with aftermarket BOV. Good Luck guys!!
You Have yourself an adjustable stock BOV now!
Attached Thumbnails DIY Better adjustable stock BOV!!  Free mod!-bov1.jpg   DIY Better adjustable stock BOV!!  Free mod!-bov6.jpg   DIY Better adjustable stock BOV!!  Free mod!-bov5.jpg   DIY Better adjustable stock BOV!!  Free mod!-bov2.jpg   DIY Better adjustable stock BOV!!  Free mod!-bov3.jpg
Old Oct 4, 2004, 01:39 PM
LightingEvo23's Avatar
haha... nice write up Kun! You always have ways to come up with cool mods.
Old Oct 4, 2004, 04:24 PM
kuniboy's Avatar
Thanks Jon!
Old Oct 5, 2004, 09:01 PM
rsboy's Avatar
This is very interesting! Can u specify what kind of screws and exactly how many did u use on yours? I just go tmy Evo, so free mods are always really good! Do u feel or hear a difference?
Thanks and cool mod!
Old Oct 6, 2004, 05:22 AM
nrcooled's Avatar
This mod is more geared to the guys that are upping the boost. It's not a performance mod, it's more like a reliablility mod.
The stocker won't hold anything over 24psi
Old Oct 6, 2004, 11:02 AM
rsboy's Avatar
Ok, understood. So this would work well if I put in a manual boost controller or something then?
Old Oct 6, 2004, 12:48 PM
sleet's Avatar
Lol nice writeup, very creative...
Old Oct 6, 2004, 03:12 PM
kuniboy's Avatar
I realized that the boost really held up. I'm boosting 21PSI. The advantage of this mod is because its free, and It really does hold up boost. Nrcooled is rite, this mod is good for people that up their boost. If the screw is tightened too tight you will get the stalling issues like the aftermarket BOV. I have been through 3 aftermarket BOVs already. And yup! Back to the stocker. 1 to 3 screws should be enough.
Old Oct 6, 2004, 03:17 PM
Guack007's Avatar
Was one of the aftermarket valves you tried the 1G? What about the MR?
Old Oct 6, 2004, 03:24 PM
AWDTurbo4's Avatar
please tell me what brands were those 3? I want to avoid them
thanks!
Old Oct 10, 2004, 06:15 PM
Lowness's Avatar
interesting......nice write up
Old Oct 10, 2004, 07:07 PM
4Gsixty3's Avatar
mods should sticky this tread.... free mod rocks!!!
good write up Kun!
Old Jan 17, 2005, 01:16 PM
YellowFever's Avatar
damn Kun - ur freaking smart
Old Jan 17, 2005, 02:08 PM
MalibuJack's Avatar
Did you find the screws leaked vacuum after you drilled it? I see what your doing here, drilling holes that line up with the spring and putting additional tension on the spring.. Once you drill the holes, you might want to point out that people should use machine screws and not self-tapping screws.. this way the spring has a flat surface to lean against... I also recommend placing 4 or 5 screws equally spaced around the perimeter of the spring seat so you have even adjustment this way you CAN hold boost over 24psi..
Old May 3, 2005, 02:52 PM
mdosu's Avatar
wow, that's so ghetto...
but very very innovative! Kudos!!
I would have tried this if I didn't already buy my Greddy Type-S...
Quick Reply: DIY Better adjustable stock BOV!! Free mod!
