Fuel pump install question? Please respond ASAP!
Old Oct 10, 2004 | 11:13 AM
sleet's Avatar
Hi, i'm currently reading the evomoto.com install on the fuel pump and I was going through my install kit that came with the pump. In the kit it includes a wire harness, 2 clamps and a peice of hose. On the evomoto.com install they dont mention using any of these things, I was just wondering if I have to use the new wiring harness and where do the clamps acually go? Thanks, please respond ASAP
Old Oct 10, 2004 | 11:33 AM
sleet's Avatar
Now when I put the pump in the filter on top gets in the way of the 3 peice clamp that goes over the pump.
Old Oct 10, 2004 | 11:56 AM
MalibuJack's Avatar
If I recall, the installation kit isn't required its just basically unused parts..
Old Oct 10, 2004 | 12:03 PM
sleet's Avatar
OK now I have a big problem!!!! The wire harens that goes from the pump into the housing has been ripped off, along with a black wire that comes from the side.
how do I get the wires back into this plastic peice that goes into the housing and where does the black wire go.
Old Oct 10, 2004 | 12:11 PM
sleet's Avatar
ok, when i tried to install the walbro i put the filter on, but then i could not install the 3 peice clamp over it because the filter got into way. so i was going to put the stock one back in and then it got jamed so i started to pull it out and the wiring came out. can I install the walbro without the 3 peice clamp over it? I need to know where that dman black wire goes and how to get these wires into the plasitc peice so i can put them back into the housing!!! OMFG im so freaked out.
Old Oct 10, 2004 | 12:43 PM
sleet's Avatar
I think that the black wire goes into the plastic peice that goes into the pump?
Attached Thumbnails Fuel pump install question? Please respond ASAP!-untitled2.jpg
Old Oct 10, 2004 | 02:16 PM
sleet's Avatar
I fixed it. They defenatly sent me the wrong fuel pump.
Old Oct 10, 2004 | 02:19 PM
Z2EVO's Avatar
yes the pumps look very much alike. you should be able to tell if they sent you the wrong one.
Old Oct 10, 2004 | 02:42 PM
sleet's Avatar
So which one did they send me? My filter goes the wrong way when I put it on the top...
Old Oct 11, 2004 | 07:27 PM
sleet's Avatar
Ok, I figured it out...after doing a few searches and looking at many pictures. They sent me the 341 fuel pump which doesnt have the ports on the same side, they are currently sending me the correct pump which is the 342 which has the ports on 1 side so the filter fits perfect.
bbyevo8u
23
Jan 30, 2009 04:16 PM
Billy17425
May 14, 2006 07:30 PM
jrsimon27
Mar 20, 2006 08:13 PM
EvoMoto
Dec 12, 2005 03:47 AM
webguy330i
Aug 17, 2005 03:20 PM
Quick Reply: Fuel pump install question? Please respond ASAP!
