Dome Light Wire
Dome Light Wire
Anybody know where I can connect aftermarket alarm dome light output to ?
I want to light the enterior when car remote is activated to lock and unlock doors.
I have a relay and dome light input wire but just need to find the car's wire to connect the relay output...
Yes. It is a "-" powered domelight so make sure you have your alarm set to -. Be careful most alarms do NOT have the domelight relay built in, most just have a 200ma output ment to run to a relay. If it has the 200ma output wire like this
85 +12v
85 - domelight trigger from alarm
87 - ground
30 - output to domelight.
Use a meter to test the wire first, I used my dei account to check for you. Use a meter and hook one end to 12v and other to the whitewire and it will read ground when door is open.
85 +12v
87 - ground
johnjonfenomeno
177
Aug 23, 2020 08:45 PM
EvoSeanzie
Feb 13, 2012 11:39 AM
