How To Mount Lancershop Autometer Steering Column Single Gauge Pod
Old Jul 28, 2005 | 11:47 PM
awdjunkies's Avatar
Thanks guys I needed this info
Old Aug 7, 2005 | 10:57 AM
Robert_K's Avatar
Wicked05: nice write up!!!
Originally Posted by burningmoney97
nice write up
i drilled a hole in the stock piece for the wires and hose http://www.hostdub.com/albums/burnin...2369.sized.jpg
Burningmoney97: Buddy and I did the same for mine. Here is my finish product:
Old Sep 22, 2006 | 11:52 AM
DanJ's Avatar
how do you remove the stock cover? Do you basically wedge a screw driver and pry it open? or are there some clips i'm missing?
Old Sep 26, 2006 | 11:17 PM
slcEvo8's Avatar
Registered User
Dan j......^^ You just unscrew 1 phillips from underneath.....
nice write up. just recieved my dual pillar, will post pics when finished.
EDIT: Just installed my 2 pillar.....i used the power source from my cigarette lighter instead of the fuse......hard wired it for a better connection and no extra wires dangling down from the install......great kit imo!!!!
Old Feb 21, 2007 | 11:59 PM
bluej20's Avatar
Here are Pics of My install....
The only thing i did diffrent was used to dremel to cut the original top piece in the shape of 1.5"x1.5" to route the vaccum line through without crimping issues...No wires or lines coming out from the back...
here are some pics
Old Apr 22, 2007 | 12:32 AM
brok3n's Avatar
Used this write up for my install. A++
Awesome finished product!
Old May 23, 2008 | 01:28 PM
SRT-TO-EVO's Avatar
This thread needs pics updated again!!
Old Jun 7, 2008 | 03:51 PM
PSIcho's Avatar
I just installed this and the damn steering wheel rubs on the new cover when I turn... anyone know how to fix this?
Old Jun 7, 2008 | 05:34 PM
EvoKnievo's Avatar
nice install!
i am adding them to my interior thread.
those are some great photos!
Old Jun 13, 2008 | 11:24 PM
evo<3's Avatar
update pics please!!!! =]]
Old Jul 25, 2008 | 10:42 PM
hytek369's Avatar
which wire do you guys tap for power? the cigarette lighter?
Old Jul 27, 2008 | 10:05 PM
IMPdemon's Avatar
I used the dimmer switch leads as suggested here, works great.
Old Aug 10, 2008 | 04:37 PM
hytek369's Avatar
+1
Old Oct 14, 2008 | 10:56 PM
evo<3's Avatar
pics pics pics!!!!!
Old Oct 16, 2008 | 08:09 PM
evoguy69's Avatar
i used a different method.i have the dual gaug pod from autometer and it mounts over the steering column.i am very particular and did not like the 4 prongs showing and was not confident that double sided tape would hold up.this is what i did. take off the factory steering column cover and drill holes in it 1/2 inch in siameter or as small as 1/4 inch.drill all over it till it looks like swiss cheese.kake sure you hav 1 or 2 holes large enough to run your wires/vac lines or whatever to your gauges.scuff up the outside of the factory piece and the inside of the autometer pice with 60-120 grit sandpaper.put the autometer pod on top of the factory steering column piece and clamp them together on all 4 sides (i have som metal clamps with little rubber covers on them they look a little like clothes pins).mix up some 2 part epoxy (doent matter what brand as long as its for plastic).take the mixed epoxy and apply it to the holes from the inside.it will glue the pieces together at all the edges where the holes are and the holes will allow it to dry thoroughly.let it dry according to the directions on the epoxy. you will be satisfied with the factory look you end up with.
Quick Reply: How To Mount Lancershop Autometer Steering Column Single Gauge Pod
