Defi D-Gauge Oil Temperature gauge intallation
Bumping an old thread...
- I've got the DEFI Oil Temp Gauge to install.
-The DEFI manual (below) states that the Oil Temp sensor has a 1/8 PT thread. (Doesn't say NPT or BSPT)
-I want to tap into the secondary plug above the oil filter (using a 42draftdesigns adapter).
Question: Which 42draftdesigns adapter to use to adapt the stock plug to the DEFI sensor (which is listed as PT, as opposed to the NPT and BSPT listed on the 42draftdesigns website). NPT or BSPT for the DEFI unit?
OR...
Will this work to simply put it in the drain plug? Does this fit evo's? http://store.42draftdesigns.com/Univ...g_p_23-58.html
OR...
![](http://img.photobucket.com/albums/v289/EclipseBlur/DefiManualOT.jpg)
boomn29
Jul 8, 2019 05:09 PM
the1tonton
Jan 30, 2013 06:56 AM
EvoIXMR
Nov 25, 2008 05:59 PM
defi, dgauge, eclipse, electrical, evo, gauge, install, installation, installing, instruction, mr, oil, sending, temp, temperature, unit
