Installed my MBC, have a question...
Originally Posted by Talon
Does it matter which direction it's pointed so long as it's hooked up to the appropriate pipes? :-/
Talon,
Hope you have managed to put the BOV the right way.
I also have another suggestion for you...the position of your MBC isn't ideal. You should use the front of the battery holder...this way you can reduce the length of your vaccum lines...the shorter the vaccum line, the better (less boost spikes, faster reaction of the MBC).
PM me if not clear...will be glad to assist.
Good luck, Tomas
Good luck, Tomas
Talon
40
Oct 23, 2006 01:15 PM
