Yet Another Amber Interior Lights -- Includes Foglight and Headlight Switches!
#34
Originally Posted by JP Neon
With all this work to make all the gauges the same color... why have a headunit that doesn't match at all?
...or is that next on the color conversion check list?...
just a question my foglight switch has an empty slot for a bulb. is there supposed to be one in there.
any btw i already did the HVAV looks really nice and i just used an ORANGE DECOCOLOR.
#35
Originally Posted by Mayhew333
Any idea on how to do the IC spray switch? I tried but couldent figure it out.
my bulb went out on this switch, so i advise everyone to do this at your own risk. the bulb isn't like the ones that you can easily switch out. the bulb sits on the little boarch itself and has like two electrical parts to it. sucks for me. but i'mma see if i can find a replacement bulb somehow. i just hope i don't have to find another switch!
#38
Just finished doin this...looks decent, I'm just going to add a little more red to my taste. The console takes little time to get apart. Like 6 screws and thats it. Thanks!
#42
I've had this on my subscribed list forever, finally started some tonight, works great. I used Elmer's "Painters" Opaque paint markers, worked nicely, nice write up, well done. Thanks !!!!!!
#43
could you be a little more specific on where the copper retaining clip needs to go on the fog button assembly.
i attempted to do this mod to my ACD button (which should be the same) and now when I push the ACD button it only remains on tarmac mode. I think I have the copper clip is in the wrong place.
any help would be appreciated.
#44
You do realize that you could get results 100X nice just going with LEDs right? Its super easy to do, and SMD leds are actually smaller than the stock bulb. You only need to measure the voltage at the output and chose the correct resistance for the LED based on ohms law.
#45
Great write up everything worked great, except now my dash dimmer, ash tray, and cigarette
lighter light wont come on. Anyone run into a similar issue and know how to fix it? The fuses
are fine and the dimmer still dims the dashboard and the cigarette litter still heats up, just no lights.
