Energy Suspension Polyurethane Bushing Master Kit Install
So far, I've done the trailing arms and the rear differential bushings. The other writeups will follow and be added in seperate additions.
Part 1: Trailing Arms
Part 2: Rear Differential Bushings
Since the polyurathane doesn't twist like the stock bonded rubber bushings you actually don't have to worry about torquing everything down with the suspension compressed anymore. Make sure that you grease the inside of the poly bushings and the ES metal sleeve, the faces of the bushings, and the subframe area that they rotate on. That will avoid future removal for squeeks, I lubed the crap out of the bushings on the eclipse and it was still noise free after three years.
Oh and DO NOT get that ES tar sap like lubricant on you or your clothes, it doesn't like to come off
Good writeup!
Good writeup!
I just got done doing the trailing arms and diff brackets. My one note is that for installing the ES one piece trailing arm bushings I found it much easier to start off in my vice. When I did them in the press (after filing more chamfer into the arm) the assembly would lean to one side and pop out. I used a piece of wood under the arm in the vice to make it so that the arm couldn't pop to the side and they went in with ease.
If you have it, an air chisel with a hammer attachment makes short order of popping out the balljoints. It took one second on the knuckle on each side for the ball joint to pop out. Even easier than using a sledge.
Good info Nick. I remember you from the DSM days, BTW.
A few weeks ago I got around to installing the front sway bar bushings and to my surprise, with the right tools, I was able to remove the sway bar brackets and reinstall with the ES bushing inserted without disassembling any other suspension components. I even left the sway bar endlinks connected to the control arms. I was surprised that with just an offset angle ratcheting wrench I was able to accomplish this, as it looks extremely difficult initially.
Would something like this work on the front swaybar bushing bracket? Any length/size considerations for the wrench?
http://www.amazon.com/dp/B0002SR058/...8&linkCode=asn
Thanks!
Thanks!
144mph
Jul 6, 2017 06:01 PM
144mph
Jun 12, 2017 03:57 PM
144mph
Jun 12, 2017 09:44 AM
144mph
Jan 29, 2016 10:36 AM
bushing, bushings, differential, eclipse, energy, es, evo, gsx, install, kit, master, polyurethane, subaru, suspension, taurus
