boost leak test
the easiest way that I haev found to boost test is to simply remove ur intake. buy a 2.5" fernco butt cap from lowes or home depot. cap off the turbo. then I remove the hose coming off my MBC that goes into the compressor outlet and blow the compressed air in there. Thats just my way tho. hope it helps.
Also Id like to add even if ur stock I would still boost test ur car. After I installed my ICPs I boost tested and the only leak I found was around my #3 cylinder lower fuel injector insulator. the funny thing is Ive never touched them. i got stock injectors still and have never pulled them. so that showes even if ur not modded boost leaks still happen.
Did you have a problem fitting the compresor into the vacum lines?
Just make one per the instructions on VFAQ. Mine only cost a few bucks to make and I used a curved piece of rad hose so it's easier to get the hose on the valve stem.
14b and 16g have the same size intake.
I wasn't sure of that so thanks for the help
[WTB] Evo 8 Throttle Body.
4b11slayer
Dec 31, 2016 01:16 PM
dudical26
26
Jul 25, 2007 02:25 PM
