Hardwire V1 to sunroof/lights?Has
I would not reccomend reoving the headliner for just a V1 install. Spend an extra 2 minutes and route down pillar to fusebox or radio harness. BTW, the requests should be posted in the post above. Moderators please move in order to keep this section clean.
https://www.evolutionm.net/forums/sh...threadid=22102 is the thread for requests on how tos. The reason I would avoid the headliner is due to headliners never going in right afterwards. I will pop the switch housing off and search for power fi I can.
News Flash!
There is no usable power in the Sunroof/Light Panel. The sunroof is using a 4 wire harness with 3 of the 4 wires emitting 3volts with the ignition on. The other is a ground. The system appears to be a reversing polarity type similar to that in power window switches. There is probably no doubt, a switched power near the motor. That would require removing the entire headliner. The light assembly does have a constant power for those that don't need their detector switched. I would recommend looking elsewhere for power, like underneath the dash.
there was a thread about this in the general section, it didnt mention any tapable wires up in the roof liner
i can see a bunch of differnt wires under the dash on the left side (driver seat) but i havent tested any. i think it would be best to tap something down below, then run a phone cord up through the pilar to the middle of the windshield.
ill be chcekin back for step by steps!
hmm, bump for whoever
there is a lot of wires under the dash, left side. i am not really experience with this type of stuff, but i did hardwire my V1 (by myself) in my previous vehicle...
i can find a nice location for the ground wire screw, and of course the tappable wires are still in question..
anybody?
anybody?
I tapped the cigarette lighter, it was easy and clean. Then I just ran the cable under the weatherstripping and up the a pillar trim to my visor where the V1 is hanging. It looks almost like a garage door opener up there.
hey nsnguyen, i tapped into my cig lighter as well with the V1 install as well, i also tapped in to it for my greddy elec. boost gauge and now my cig lighter doesn't work any more, not that i would ever smoke in my evo but it would be nice to charge my phone on the road, does your cig lighter still function???
8OhOh2
May 14, 2016 06:39 PM
2006MRevo
50
May 17, 2010 07:48 PM
dudical26
16
Jun 6, 2007 01:13 PM
