Tuning the Profec B spec II--simple version
Old Sep 5, 2009, 08:51 PM
  #46
JRR
JRR's Avatar
anyone?
Old Sep 6, 2009, 11:15 AM
  #47
EGbeater's Avatar
Originally Posted by JRR
here are my settings:
low:
set 50%
gain 5%
set gain 20
warning 70
warning limiter 10%
hi:
set 100%
gain 5%
set gain 40
warning 75
warning limiter 10%
i have a tial external wastegate with a 7psi spring. my top boost was 10.8 psi.
i think i need to adjust a few things. i want my low to be about 4-5 psi and high to be like 8 or so. that way i can change from fuel economy to race mode.
If you're exceeding your desired high boost level by 2.8 psi, I'd guess you need to back down the set percentage and/or the set gain.
i also noticed that when on low boost it starts "clicking" at about 2 psi or so. is this normal or something not hooked up right? i does not do it on the high setting.
Clicking? There's no mechanical components inside of the Profec controller to make any noises... are you saying you're hearing the solenoid all the way from the engine compartment, while driving?
In any case, I have no idea if/when my Profec's solenoid clicks - my Evo is so loud, I probably couldn't hear the solenoid making any noises even if it was mounted on top of my dash.
Old Sep 6, 2009, 02:19 PM
  #48
JRR
JRR's Avatar
thanks i will look into that. as for the "clicking" i found here on the forum that it is a normal thing and not to worry about it.
should i lower both the set ans the set gain on both high and low?
josh
Old Sep 7, 2009, 07:38 PM
  #49
JRR
JRR's Avatar
current:
low...
set 50%
gain 5%
set gain 20
warning 70
w. limiter 10%
high...
set 100%
gain 5%
set gain 40
warning 75
w. limiter 10%
i think...
if i lower my set on the low side to 40% and my set gain to 10, and on the high side my set to 75% and set gain to 30, my boost should go down.
if anyone wants to take a crak at it here is the manual from greddy.
http://www.greddy.com/img/PHP/products/pdf/682.pdf
josh
ok so with the above info that i "adjusted" today to the values, i hit a 13.3 psi on high!
then i had some bov flutter, and found out that i had melted the vacuum line from the bov to the fpr had melted!
josh
Old Sep 8, 2009, 12:29 PM
  #50
l EVO n's Avatar
josh
whats the fpr?
Old Sep 8, 2009, 03:07 PM
  #51
EGbeater's Avatar
FPR = fuel pressure regulator
Old Sep 8, 2009, 03:28 PM
  #52
JRR
JRR's Avatar
anyone wth a recommendation on what i should try? like i mentioned i lowered it and my boost went up?
Old Sep 18, 2009, 09:44 PM
  #53
kaj
kaj's Avatar
so many pages.. has anyone asked?
i am getting 21-18-21-18-21psi.
my settings:
gain: 52%
gain: 5%
setgain: 150 (15psi)
warning: 230 (23psi). trying to reach 21psi in 3rd gear.
warning L: 15%
peak boost was: 214 (21.4psi).
it's acting like it's hitting the warning level, though peak is clearly lower. any ideas??
Old Sep 18, 2009, 09:46 PM
  #54
kaj
kaj's Avatar
josh
any thoughts?
not sure if it's related.. but mine did the same thing. i swapped the vacuum lines on the solenoid. problem fixed. weird.. because i hooked them up per instructions. or so i thought.
Old Sep 18, 2009, 10:12 PM
  #55
JRR
JRR's Avatar
u runnin an external wastegate or the stock one?
i have an external and it says for me to run the top one into the "com" side and then out to the "no" side.
josh
Old Sep 19, 2009, 08:50 AM
  #56
kaj
kaj's Avatar
josh
2 things.
1. i have the stock setup. instructions said to run "com" to turbo and "no" to wastegate actuator.
i DOUBLE checked the lines.. maybe i'm crazy.. but i had them that way and the more i'd increase SET, the lower boost i'd run. WTF??
so.. i swapped them. now it works.
2. as for the solenoid clicking, i found it was 'cause i started my GAIN and SET GAIN at 0. well.. duh.. with SET GAIN at 0, the solenoid is working as soon as boost starts. that's why my solenoid was clicking.
is it your solenoid that's clicking?
Old Sep 19, 2009, 10:17 AM
  #57
kaj
kaj's Avatar
a few things i've noticed in this thread:
Originally Posted by EvoIIIAj
Guys I need help.
My boost is dropping off from 20PSI to about 15PSI.
Here are my settings:
GAIN: 15%
Start Boost: 0.80BAR
SET: 73%
Warning 1.65BAR
Any recommendations? It is an Evo III.
i'd say the 15% gain setting is causing your boost spike. your bar > psi is messing me up. LOL.
Originally Posted by revvin9k
I have an Evo 8 and i'm tuned for 24 psi. I had it locked at 22psi when I was tuned for it. Been a bit of an uphill batle trying to get it to stay at 24psi.
My settings are:
set: 68
start boost: 20
gain: 6
limiter: .4
warning: 250
Takes a bit to get it right. Any ideas?
your start boost is set at 2.0 psi. so, your wastegate is opening REALLY early. can you hear the solenoid clicking at low boost? do you suffer from slow spool?
EVO TYME!
For Sale - Cars For Sale
Oct 24, 2014 07:14 PM
evil_evo
26
Jun 14, 2011 03:27 AM
Jimbolution
Jun 3, 2009 05:28 AM
Freddy302
27
Sep 10, 2008 10:12 AM
Freddy302
76
Sep 20, 2007 10:19 AM
Quick Reply: Tuning the Profec B spec II--simple version
