Jun B.L install + lessons learned
Also if your having trouble getting the o2 sensor out you can pull the wire out from the top of the car and you can unplug it so you dont end up twisting the wire up.
Also when putting it on v-clamp everything up but leave loose so its easier for yourself when putting the hangers on.
If you have a test pipe and have a CEL on you have is spark plug spacers that will make the code go away. I believe you us the 18mm size, and you take one and drill a 1/2 in hole through one and us that one to screw into the o2 sensor. Otherwise you cant screw it in. Then screw the other spark plug spacer in the bottom of the one you drilled the 1/2in hole into. Then screw it into the test pipe.
I found a write up on how to on the forums:
https://www.evolutionm.net/forums/sh...d.php?t=208195
Same things that helped me and hope will help you!
MJ23FE
Mar 15, 2009 10:06 PM
