How do I remove the center console?
I'd like to get access to the parking brake wiring. How can I remove the console? I know the front end (towards the shifter) simply snaps out, but what about the rear end?
Also, can someone tell me how to remove the plastic door sills? Do those snap in/out also?
This is really easy. First simply remove the two screws in the center console under the arm rest/door. Then as you said just pull up on the front where there are two snaps and it just comes right out. Easy as it gets.
Thanks guys. I looked earlier, albeit briefly and I didn't see any screws at the bottom of the arm rest bin.. then again, I had a bunch of stuff in there that I just moved around carelessly. I'll take a closer look tomorrow. I appreciate the quick replies.
DRFTKNGG
May 31, 2016 04:46 PM
gerazz
Nov 18, 2009 09:01 PM
webguy330i
Apr 12, 2004 11:53 PM
