serpetine/drive belt HELp
i seach all over this forum.. can some one plz get me a diagram of how the drive/serpetine belt is routed. and how to change the belt.
i have it taken off but i can't get the last routed in.. i am like 2mm alway. is there a specific last one to put in?
When I did it I had to pry the belt back on. I got a screwdriver and got it between the crank pulley and belt, push down, move a little, push down, and so on. It will go, just takes a little persuasion.
I ran into the same problem as you, I could find anywhere how to route the belt, not under the hood, not in the manual, not on here, no where. But I thought about this before I took it off, so I drew a picture of the routing. Don't know where the pic is anymore, but if you need it I can go out and look at my car, draw another one.
Hope this help.
http://www.socalevo.net/index.php?op...&topic=27340.0
