exhaust install
exhaust install
need help in trying to figure out what the problem is with this exhaust install; i think that it is the downpipe, but just wanted some opinions; i have a new agency power ti catback with a perrin hfc and a perrin dp; i dont think that this is a perrin dp; bought it from a member here, but anyways; the problem that i am having is the everything lines up good except the dp; tried to swith pipes around vice versa, but to no avail; any opinions would be great, thanks;
here are some pics
here are some pics
is the downpipe for a IX or from a 2005 VIII? or is it from a previous VIII? i dont understand why it would not line up if you are putting everything in the right place....
and the pics dont really show much
I did my install starting from the front and working my way back. I thought I remember reading that Perrin re-did their dp design to accomodate the ACD cars. Yours might be an older one.
I also had problems with my exhaust install because the perrin HFC had warped flanges. When I tightened them down, it would pull the exhaust closer to the drive shaft and the carrier bearing shield/bracket. I had to break out the "persuader" (5 lb mini sledge hammer) and hammer the flanges. It's not perfect, but so far, it's working. Check how straight the flanges are.
evo unknown
10
Dec 15, 2009 10:13 PM
morfhious3
12
Aug 3, 2009 05:59 PM
