Where the heck is the coolant drain plug
(didnt read other responses)
u dont need to remove the whole undertray. if u look, there is a small panel in the front and slightly towards the passenger side. that panel uncovers a small black plastic nut on the bottom of the radiator. loosen the nut and radiator fluid drains.....
i dont feel u need to get to the engine drain plug also if u follow a cleaning procedure in between.... case u dont know the correct procedures of radiator flush, do research on google.
