Power locks and Cigarette lighter not working.
Old Dec 11, 2007 | 08:04 PM
Jacoby's Avatar
Question Power locks and Cigarette lighter not working.
I was using the cigarette lighter to power an air pump when it suddenly stopped working. Now my power locks and remote entry do not work as well as the cigarette lighter.
I checked the fuse under the steering wheel and it is fine. Where else can I check?
Old Dec 11, 2007 | 08:13 PM
CBRicahrd's Avatar
i would double check the fuse, switch in another known good fuse.
Old Dec 11, 2007 | 08:38 PM
KcEvil8's Avatar
there is another fuse box under the hood
Old Dec 12, 2007 | 05:57 AM
EvilBlueEvo8's Avatar
use a continuity tester and test them all. there are two boxes. one under the dash and one under the hood. don't replace them with higher amperage ones. you'll run the risk of causing a fire. it is a blow fuse btw. overload of the circuit with that pump.
Old Dec 12, 2007 | 06:13 AM
mifesto's Avatar
how did u 'check' it. did u visually? sometimes thats not good enough. volt meter is best as somethings burnt fuses look 'connected' but are completely dead.
Old Dec 12, 2007 | 09:36 AM
Jacoby's Avatar
Ok.. So I got the power locks ones replaced. They are under the hood.
But the cigarette lighter fuse under the steering wheel is fine and I even swapped in a new 15A and it still wont work. Is there another fuse somewhere along the circuit or did I screw something else up?
Old Dec 12, 2007 | 02:13 PM
Jacoby's Avatar
bump
Old Sep 8, 2008 | 05:07 PM
wshihdnevo's Avatar
Same problem here w/ the lighter. I basically did the same thing, but only my cig lighter doesnt work...bump for an ancient thread...
Old Sep 8, 2008 | 06:14 PM
BoostLover99's Avatar
I had the same problem w/ power locks. Check your dome light fuse in the engine compartment. The dome light fuse runs the dome lights (duh) but also the power locks & windows when the ignition is not on. It also runs your clock and trip odometer (!)
It's surrounded by a yellow plastic thing that is *extremely* difficult to get out; you'll have to use 2 flathead screwdrivers to do it - be careful not to bend or break anything around it.
Old Jan 28, 2009 | 09:33 AM
anthony_86gt's Avatar
I just bought my EVO VIII a few days ago and I am having a problem where the cigarette lighter, ashtray light, and power door locks do not work. I have checked all the fuses and even replaced them and still nothing. Everything else works. I have taken out the lower connector on the fuse box and when I put it back in it locks the doors?! What color wires should I track down or what should I look for? Thanks!
Old Jan 28, 2009 | 04:10 PM
Aman's Avatar
check the fuses in the picture.
Old Jan 29, 2009 | 08:00 AM
Thanks for the info but i changed them even though they were good and still nothing. I will check it out again and flip some around and see but i dont think that is the fix. any other suggestions? thanks for the tips so far.
Old Feb 8, 2009 | 06:29 PM
i just got a keyless remote for my car and the door locks work with it. still doesn't work manually with the switches inside the car. and still the cigarette lighter and the light for it and the ashtray don't work. i have checked EVERY fuse and still nothing. anyone have any suggestions?
Old Feb 10, 2009 | 08:22 PM
well the cigarette lighter ended up being a burned up wire that is located on the cigarette lighter socket. there is a little black wire that is in place like a fuse on the socket. didn't see it the first time. now if only i can figure out the door locks!
Old Jul 20, 2010 | 07:19 PM
milford's Avatar
bump from the dead..both fuses are good and door locks still dont work. idk what to do. i cant find anything else on this problem here. please reply if you know something that may help. thanks
Quick Reply: Power locks and Cigarette lighter not working.
