Turbo removal...
Old Feb 1, 2008, 06:15 PM
urslo4n8's Avatar
Turbo removal...
Ok well i dont know how or why but when removing my exhaust manifold i snapped one of the bolts where it bolts up to the turbo. So im going to remove the turbo to remove the bolt and possibly re-tap the bolt hole. After removing the downpipe and the oil lines to the turbo as well as the intake, what else do i need to remove for instance is there a bracket to the block or anything? this is my first time removing it so any advice is appreciated thanks in advance guys.
Old Feb 1, 2008, 06:20 PM
ak47po's Avatar
Should have done more research BEFORE you started.
Old Feb 1, 2008, 06:24 PM
urslo4n8's Avatar
well thats no help not even worth the reply thanks for nothing
Old Feb 1, 2008, 06:25 PM
ak47po's Avatar
Don't mention it.
Old Feb 1, 2008, 06:30 PM
urslo4n8's Avatar
Don't mention it.
actually i have to laugh at that even though it was a jerkoff reply
Old Feb 1, 2008, 06:31 PM
urslo4n8's Avatar
now how bout some help slappy
Old Feb 1, 2008, 06:33 PM
ak47po's Avatar
I was going to help,but now that you called be "slappy" forget about it.
Old Feb 1, 2008, 06:36 PM
urslo4n8's Avatar
oh stop if you were then you WOULD have slappy
Cal City Evo's Avatar
Possibly the starter. That is about all I can think of off the top of my head. Might be easier to pull the whole manifold though. You may have a repeat of the other bolts if you don't soak them with penetration type of stuff.
Old Feb 1, 2008, 06:37 PM
03RRVIII's Avatar
there is on bolt right under the turbo just incase you dont know yet! other than that is just all about removing the bolts of the exhaust manifold, disconneting oil lines, one on top, 1 on the oil pan, vacuunm lines, and some coolant lines on top. last thing the Lower Intercooler Pipe... if i miss other thing, others can chime in
to make it easy drain your coolant and pull the Radiator out
Old Feb 1, 2008, 06:39 PM
urslo4n8's Avatar
Originally Posted by 03RRVIII
there is on bolt right under the turbo just incase you dont know yet! other than that is just all about removing the bolts of the exhaust manifold, disconneting oil lines, one on top, 1 on the oil pan, vacuunm lines, and some coolant lines on top... if i miss other thing, others can chime in
thanks for the help
Old Feb 1, 2008, 06:41 PM
03RRVIII's Avatar
thanks for the help
no prob
Old Mar 13, 2008, 08:42 AM
voidhawk's Avatar
any follow-up on this, how hard was it? Need to remove mine too and would appreciate any hints.
Old Mar 13, 2008, 11:28 AM
SLO-EVO's Avatar
for ease of taking out the turbo drain then take out the radiator... other than that it just like the above posts, the coolant lines, oil return lines, exhaust manifold, downpipe, and it sould come out with ease...
Old Mar 13, 2008, 12:04 PM
MR Turco's Avatar
i am probably late on this but you can easily remove the hot side of the turbo without removing the turbo in the car. Just remove the v-band clamp and nicely tap the hotside off the center section. It is pretty much a guaranty that either one of the two bolts or two nuts on the exhaust mani to hotside with seize or strip. I have never seen anyone remove the exhaust mani without having this problem, myself included.
Quick Reply: Turbo removal...
