manual boost controller install help
I was thinking about installing an MBC; but how in the world do you get to the hose on the turbo actuator. I believe the mbc needs to be connected to the turbo actuator and also T'd into the line in between the factory DV and intake manifold? What do I need to remove to get to the hose on the actuator? Is there an easier way?
03, 16g, boost, control, controller, evo, evolution, evolutionm, guide, instal, install, installation, installing, jdm, manual
