Buschur Front Undertray Install
So, if your going to drill the holes, why don't you just buy a sheet of metal and make it yourself since you are so handy with the tools. Seems like a crappy design to me. A more practical one would be the Undertray made by beatrush. Just think Buschur could've put a little more thought into the design.
Their is more to it then just buying an aluminum sheet. I was originally going to do that but then they wanted $150 just for the sheet. Then you have to go through the trouble of designing it. Not as easy as you would think. For the little extra money it is already made for you. This is a simple design to serve a simple function. This is not something that needs the bling factor or to be shown off. So far instead of the steering wheel starting to shake at 90mph it starts at 120mph.
1. It takes 5 minutes to take the tray on and off.. so you have that option.. or you can cut a hole in it for the oil to drain out..
2. You must cut a hole for the gases to get out of the external dump..
To answer your questions... (from what I read in this thread)..
EvoM Community Team
Also, in the original thread bushur stated that he didn't make trap doors for the filter and oil drain because sometimes when guys go off track it allows bad things to happen... some real life examples were provided. This was made to be pretty easy to take off for your oil change.
If you don't like using the stock dzus fasteners you can use standars screws or a number of other options.
Thanks for the write-up!
