Install Advice (basic bolt ons)
Hey I'm installing full turbo back with test pipe, EPM LP2, JDM REAR and ETS LP2 on Saturday and was wondering if anyone can give me some last minute advice, tips & tricks, or even things to be weary of. Thanks
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
Well here it goes. For one do your research before you start the installations so you know what to expect and what you are getting yourself into. For example with your JDM rear are you aware that your factory crash beam needs to either be modified or removed?There is a wealth of knowlege on this site with many how tos and such. Another thing would be to soak your bolts with PB Blaster prior to the installation. It will be your best friend. Hope this helps!
