Radiator install help needed
Holy hell.
i've got a hole in my stock radiator and now have a new one with a slim fan. (both are mishimoto products).
this thing does NOT look like it will fit with all factory evo ix components. (ie stock upper and lower intercooler pipes... i've seen with picture of one installed with an aftermarket one)
anyone every successfully installed a mishimoto radiator (with stock fan or aftermarket) and had it fit? or more importantly does anyone know how to do it on an evo ix?
please god someone say yes.
yes they have look at my sig. I have a evo 8 but its the same as evo 9. I have a full install guide of the radaitor on my car page check it out. http://www.cardomain.com/ride/3123213/12
here is a very old installed pic. i have had it in since last thanksgiving installed it myself no issues at all raditor is perfect
well i just replaced the stock radiator with the mishimoto one and it definitely wont fit the stock fan/shroud with stock uicp hoses. nor will the mishimoto radiator fit the dual slim fan.
haha maybe i have the wrong part but that thing isnt even close to fitting. the mishimoto radiator is about 1 cm from the turbo heat shield. no room for anything there. maybe a finger but that sounds like a bad idea.
for now im running on one fan (because neither the stock fan and shroud nor the mishimoto dual slim fan and shroud will fit with the mishimoto radiator in place) so no stop and go hot daylight traffic for me.
one more thing. its actually rubbing against what ever that metal piping is located on the passenger side of the radiator. this b**** is HUGE! hehe.
all in all, it wasn't too bad of an install (and i'm about as novice as one can be). I'll never have to deal with that blood thirsty fan shroud that mitsu puts in there ever again. i think the rabbit from monty python's holy grail was reincarnated into the machines that build those units. good riddance.
thanks to those who offered advice. evom rocks.
YOU GOT THE WRONG PART FOR SURE. did you check out my install guide and my pic above the radaitor slide right in no issues with fitment or touching anything not the mention im using the OEM FAN. you bought the wrong one and yours is not made for a evo and prepare for some problems to arise. As sugguested above you need to get the correct EVO SPECIFIC radaitor and send that one back if you need assistance with finding the right one feel free to pm me but i had no issues and fit fine. you can find PLENTY more pics on my website and see it sit perfectly flush and not touching a thing
Its now 2011 and same problem. Some spots are small clearance...others are zero clearance. I'm worried about chafing and premature failure... Working on issue resolution...
SnailSpeed
Oct 11, 2015 12:35 PM
