elec. boost contr. settings help
hello today i installed a greddy profec B II in my evo. i have followed the directions to a T and the car is boosting exactly half of what it does stock. i changed the reading to PSI from bars and i know they post it by tens example 14.5psi is 145 and 10.0PSI is 100. now i want to set my high setting at like 19-20 PSI. this should be 190-200 on the damn thing but it only goes to 100. how do i switch it to make it go higher than 100. i am only pushing 10PSI and want 19-20. anyone have this EBC and know how i can fix this setting?? thanks
hey man, i just installed the same boost controller on my bussys evo, the setting should be as follows, set them up in order that they appear on the menu screen, 6, then 20, then 65%. that should make ur evo boost to 19lbs and hold there if u have any questions about it instant message me on AIM bw92integra
alright thanks man. i put my low boost setting at 20 and the high one at 65 and its working a bit better now. basicly what i want to know is what you set the low and high at, as well as the gain, warning, and all that stuff. thanks, shoot me an email, pm, or whatever. my IM is on here also.
I have the gain at 16 on mine. It takes 50% to get to 19 psi on mine. It will spike to 20 or 21 in the cold in some situations, but will hold 19 psi to redline. I have my start boost setting at about 3 or 4 psi below my boost setting. For example if I am boosting to 19 psi, I will set the start boost to 16 psi. This seems to work out well. I also have my warning set to 22 psi, and I drop 3% if it hits the warning setting for over 1 second.
Low boost setting = 16 psi, ~40% on the boost setting.
Hope that helps.
Brian
Hope that helps.
Brian
EVOEvolved
Apr 3, 2017 06:13 AM
crasher
Jan 11, 2007 08:57 AM
