Circle earthing hyper ground
![Question](https://www.evolutionm.net/forums/images/icons/icon5.gif)
Ran a search and found no circle set ups so:
Does anyone have a picture on where to mount the circle thing and where all the rest of the wires are attached. Or maybe just list where they attach, I have a 2- 33", 2 - 27", 1- 21", 1- 17", and 1- 12", plus a little metal bracket, and they are all attached to the circle
It came with 0 instructions and all I could find is info on the normal hypers and not the circles.
thanks
thanks
I know the circle is usually mounted near or on the battery and connected to the negative terminal ..
Search for ground kit there are some pics on the board.
Also point most people have been attaching their grounds are to the tranny the back of the head the intake and the drivers and passengers side engine compartment.
Originally posted by Sano
thanks jamdown, that kit has 8 and mine has 6 does anyone know which grounds I would not use.
I ditched the circle thing, my hood would not close after I attatched it to the negative battary cable.
I got this kit off ebay, the wires are good, and the circle piece would be ok if you attatched to somthing like the hks kit.
Bad part zero instructions, a bunch of peices with no home. I ended up just grounding them to places I saw on the site. the ebay kit is good if you know exactly what your doing, but I still don't get the circle piece.
Sano, As long as you are grouding different points of the motor and they all get back to the negative terminal of the battery you are good. If you want a picture of mine let me know.
Basically they all need to flow back to it one way or the other. For example I have two wires attached to the negative terminal one wire grounds on the right side of the quarterpannel where the factory ground is and the other one grounds to a bolt on the valve cover with two other wires running off of it going to a Intake bolt and a bolt holding a hanger on the side of the head. then I have two other places grounded going back to the intake bolt and these are the firewall and the left quarterpannel. I will try and get you a pic but basically you will want to end up have a end connection on the negative battery terminal. I have attached a link that I used to do my install.
https://www.evolutionm.net/forums/sh...grounding+kits
