exedy twin disc question
What do you mean? You should be using the alignment tool for the discs themselves, for the plates they should go in order and aligned with the paint marks from the factory. The transmission will not go in unless the discs are aligned perfectly.
Theres a hole on the top of the plates.........
Here...
http://www.exedyusa.com/multimedia/s...twin_notes.pdf
Here...
1 Post
Actually, Exedy specifically puts inspection holes in the friction discs and states "the discs should be rotated slightly so that the friction areas do NOT line up exactly"
Feel free to ask any more technical questions and I'll help you out.
Josh
Josh
I bought my evo used from a dealer and my buddy pulled a plug from the front of the tranny and said it has a exedy clutch. What would I look at to verify what type of clutch it has twin, triple without taking the clutch out?
jason42003
Jan 16, 2014 02:52 PM
subrwho
23
Jun 25, 2010 03:38 AM
