Replacing The Negative Battery Terminal Clamp - 2003 EVO 8
Old Mar 6, 2011, 11:08 AM
novabluebyyou's Avatar
Anyone have any luck replacing a broken negative battery terminal clamp?
Mitsubishi doesn't sell them (you have to buy complete wiring harness) and there appears to be no slack in the cable to allow for use of a universal replacement clamp.
Thanks in advance for any advice you can provide!
Old Sep 27, 2013, 06:32 PM
Coxor's Avatar
I have the same problem... no slack. What did you end up doing, novabluebyyou?
Old Jan 24, 2014, 10:25 AM
evo8sk8's Avatar
i have the same problem on my EVO8....what was the best solution?
Old Sep 2, 2014, 02:03 AM
DarkEvoSe's Avatar
can any of you guys give an update as to what you did, i need to replace mine and of course the wire is to short, I'm thinking of cutting the wire at the break and then just running some 4 gauge from the battery to that grounding bolt
Old Sep 21, 2014, 02:23 AM
Name User's Avatar
Looking for the same answer. Just saw a few people talking about getting a "longer negative wire" here but no details:
https://www.evolutionm.net/forums/ev...tall-help.html
Old Oct 13, 2014, 06:47 PM
evoholic's Avatar
So what I just did was get a NOCO P/N: TZ1290CS. It has the normal part that clamps to the terminal post and at the other end, it has a flat plate and a bolt. I cut off the broken end from the original clamp, drilled a hole in the flat part that remained, scuffed up the flat part on both sides, put the NOCO part through it and bolted it together. I added a lock washer too just in case.
I attached a pic of the part. HTH
I'll try and get a pic tomorrow of what it looks like on the car
Attached Thumbnails Replacing The Negative Battery Terminal Clamp - 2003 EVO 8-20141013_184243.jpg
Old Mar 13, 2015, 07:31 PM
evoracing's Avatar
Anyone figured out another option for replacing the negative battery terminal? I unfortunately cut the cable thinking a replacement at a auto parts store would be fine. But to no surprise Mitsubishi's great design team screwed me on that one too.Cable is too short with any replacement terminal.
Old Mar 14, 2015, 08:28 AM
CoachG's Avatar
I used a quick disconnect terminal for a while to solve this problem. The two piece design added enough length to allow for an easier connection to the neg terminal. The cable itself did eventually fail and was spliced and replaced.
DarkAngelOfDoom
Feb 21, 2011 02:31 PM
Solley
Apr 15, 2010 10:36 AM
MitsuJDM
Dec 3, 2008 12:09 PM
propellerhead
Oct 15, 2004 07:23 PM
schleppy
Sep 6, 2004 06:41 PM
Quick Reply: Replacing The Negative Battery Terminal Clamp - 2003 EVO 8
