Safc 2 install
you can use road race engineerings ECU diagram on their website at http://www.roadraceengineering.com, and also a little note...in the SAFCII manual, the diagram for the evo 8 is not right, use the one for the 2nd gen eclipse...If i remember right it is the diagram M3-a or something like that, other than that, that should be all you need. good luck !!
I dont have the manual unfortunately because I bought mine used and that acrobat reader wont load for me because it says I need the latest Japanese language support package. Can you send me in a email that specific diagram or section to justinnorton@comcast.net please. BTW thanks for all the help everyone.
Originally Posted by mvm42699
is it necessary to have the airflow signal wire cut then bridging it with pink wire (closest to ecu) and orange wire?
neither...use the power coming through your ecu....
https://www.evolutionm.net/forums/sh...light=safc+pin
