How Do you Change oil in Evo??
I have an evo, question is i dont know how to change oil w/ this specific car. Where's the filter located, oil drain plug etc. do i also change the other fluids as well like differential, tranny fluids at same time?
The oil drain plug and filter are right next to each other behind the passenger wheel (well, not directly behind it and you don't need to pull the wheel ). Get under the car and you'll see them. You'll also need to replace the crush washer on the drain plug when you change your oil so pick some up from the dealership. As for the other fluids, they won't need changing yet if this is your first oil change.
You could follow technical instructions from this forum, but it still ends up like this..
http://www.ahajokes.com/red87.html
RA2013
Jun 19, 2015 07:43 AM
