Torque specifications for cam install
Where is the best place to go in order to get the torquing specifications for everything when doing an HKS cam install?
Here are a few more pointers:
One thing I've always done during my cam installs were to drain the lifters by sticking a small allen wrench down the hole. Once you remove the stock cams, the lifters will become fully extended. I've heard of people bending valves when they first start their cars up after a cam install, so I always drain them as a pre-caution. You'll hear a lot of chatter when after you start up your car, but it goes away after a 5-10 minutes of idling.
And don't forget to lube all mating surfaces with assembly lube or motor oil. Some people like to change their oil right after the install as an extra precaution. I did mine a week after.
You can just follow the directions from EVOMOTO
Here is the link:
http://www.evomoto.com/tech_info.php?techID=18
It has everything you need, torque specs and all. I just installed my 272s last week. Install went nicely. Check out their Evo Tech section they got plenty of info.
Hope this helps....
Here is the link:
Hope this helps....
GreddyEvo
Jun 8, 2006 01:17 PM
