How do I remove the stock airbox ?
I plan on installing my MBC and in order to do so i've heard that you should remove the stock air box. All I can see so far are the 2 bolts, one at the bottom of the airbox and one on the right side, what size are these bolts? Is there anything else that is holding the airbox in that I should know of?
Mine aren't 10mm, anyone elses not 10mm? I put a 10mm wratchet on there and it was way too big.
Originally Posted by machron1
Jesus for ****'s sake man. If you can't figure out how to remove 2 bolts I suggest you close your hood and pretend there are fluffy little bunnies under there pulling you everywhere you go. If your bunnies need care, take them to a specialist.
damn....why are you all jumping on this guy. he didnt say he couldn't figure out how to take them off. he said he HAS a 10mm wratchet and it seems too big. he didn't say which way do i turn the bolts. stop being a d*** and help the guy out if you know what he is talking about otherwise don't bother posting. excellent "how to" forum eh?
Check this link:
http://www.evomoto.com/tech_info.php?techID=14
Step 1-8 describes how to remove the air box. Also if the 10mm bolt doesn't work move to the next bigger/smaller size.
Originally Posted by Thoe99
Thanx alfredob1, I'm doing an MBC install tomorrow morning. I was looking under the hood today just messing around, but I could not remove the stock airbox either! They are 10mm bolts, by the way.
If you're close to Pearland then drop me a PM and I can help you this weekend if you want to drive over.
Yeah, I got the right bolt size and everything now. I'm gonna do the whole install on saturday so the engine can cool overnight so I don't burn my hands to hell.
