dynomat on the front door??
Hello all.
how do i put dynomat on the front door?
after taking out the plastic panel, i see vinyl glued to the door with black sticky stuff(i don't know what they are called).
do i remove vinyl cover and black sticky and cover with dynomat?
Or, do i just pull out vinyl cover and put dynomat over the black sticky?
thanks
thanks
Never done the Evo, but have done plenty of other cars. Don't even try to remove that black stuff, unless you want it all over your clothes and car. Best thing to do is cut the plastic out around the black stuff (leave plastic on the black stuff) and dynomat over it. If you expose the black sticky stuff, you're just asking to accidentally bump into it and get it everywhere.
