Perrin Oil Catch can Installation w/ pics
What would I do since I have an aftermarket intake hose between the maf and the turbo and it dosn't have the breather nipple on it. right now i have a breather filter coming off of the side of the valve cover. Its currently black from the oil so i am seriously looking at getting a oil catcch can for my system.
I also bought the Perrin can. One other thing I'd add is that some of the kits now come with plastic nipples to screw into the top instead of brass. DON"T USE THEM. They have a nasty tendency of breaking if you overtighten or put any stress on them. I bought two new brass nipples at my local auto parts store for a few bucks.
A note on draining it -- I think you won't have to remove it to do a drain. An old water bottle held underneath the can should be sufficient to catch any oil, and you can use the clear level hose as a drain.
Learn from my mistake. Avoid this Perrin can - it does nothing. If you're really interested in getting a can that actually traps oil vapor, purchase one of these: http://www.saikoumichi.com/
I run the DC3 dual on my Evo and it works - amazing the crap that comes out of it. When I had my Perrin on - literally nothing would collect in it. I finally decided to take it off when it failed (the plastic sight hose would come loose from its fittings, and one of the nozzles fused to the metal top (don't know much about metallurgy, but someone pointed out that the two different metals used have a habit of seizing together when threaded together).
Edit:
To be more specific, what vent line did you tap into for the second tank on your Dual DC3? I imagine the first tank is fed just like your previous Perrin setup, as posted on your own site.
No write-up, and the car isn't here for me to snag photos of currently (it's getting a cage installed). One tank has the line from the valve cover going into the top, and the line out the side goes to the breather on the intake. On the 2nd tank, the line out of the PCV valve goes into the top of the 2nd tank, and the line out of the side goes into the intake manifold.
I have the dual unit mounted on the driver's side fender rail, and I reused a bolt that held something on (boost solenoid? hard to recall) in that location. It basically ends up under the intake's filter on my car. When I purchased they offered an install kit that included hose and clamps to make it all inclusive for the task.
Any other questions?
