Has anyone used a Raptor Shift Light
Has anyone used a Raptor Shift Light? Would this work in an Evo8? Does it have a Tach wire to tap into and where would you find it? It seems like a cheap/cool/easy solution.
http://www.raptorperformance.com/
I personally have a Proform shift light, the only thing I don't like about it is that the EVO does not have a very clean tach signal so for some reason it will blink when sitting at a stop or especially when I pull the key and let the turbo timer cool it down. Before you g et skeptical I have checked connections and they are all good. I personally only use the shift light at night.
