Swapping MR gauges to aftermarket
Looking to swap my MR gauges (boost, volts, temp) for aftermarket versions and wanted to know if i could wire the new gauges using the existing MR gauge wiring? Of course, the new gauges would be boost, volt, and oil temp. Has anyone tried this?
Probably not going to happen. The stock bezel will need some serious cutting. Also the temp sender for oil temp will need to be replaced for the new gauge. You could however use the power wires, but its pretty much easier (and lighter) to remove the stock gauge harness from in between the radio harness and just tap power/ground/illum from the stock radio harness. That MR wiring boomslang type harness is a mess! Holy crap is it a mess. I have successfully removed all traces of my MR gauges (except for about 4 feet of wire that is virtually impossible to get to, and installed aftermarkets in various places. I could help you out, just post what you got!
Thanks for your reply! I'm looking at getting a set of Autometer gauges in possibly Phantom II series. I was also going to get the Autometer triple gauge bezel for the stock radio location so the whole MR bezel would be replaced anyway.
I guess it would be best to start from scratch then eh? No problem, i've done gauges before many times. I just thought i'd ask to see if there was an easier way lol
Thanks!
Thanks!
FS[MidWest]: FS: Evo MR/RS Triple Gauge Pod
Squatch
Mar 16, 2017 10:03 PM
VicVoss
Sep 28, 2016 06:37 PM
Robertv34
Sep 5, 2012 06:24 PM
